Hi Everybody!
I’m planning to update my computer. First step will be buying a SSD. I’ve read a bit but I’m a little bit lost. Maybe you can help me.
Right now I have an Asus PK5 Deluxe motherboard that supports SATA II but I’m thinking to buy soon a new P67 motherboard with an i7 2600 K processor (which will support SATA III). My OS is Vista Ultimate 64 bits (no plans to upgrade to windows 7 if is not a must!).
I want to buy first the SSD and install it on my current computer. I’ve seen basically two SATA III SSD that are the OCZ Vertex 3 and the intel 510. I’ve seen the benchmarks here in anandtech and it seems that OCZ is better than Intel in most of the features. Also both of them seems to be able to run under SATAII. I will not get the best of them until I buy the new motherboard, but it does not worry me at that time.
Which one of these 2 SSD will you recommend me? I want the best features but basically I need reliability. If the OCZ runs faster but lasts less time then I prefer another SSD.
Also, will I have problems to configure it under Vista? What are the main issues that I have to think about when installing under windows vista and with my current motherboard?(I plan to move all the OS to the new SSD, not installing it from zero)
I would really appreciate if you could give me dome advice and help! And sorry if I did not make myself understood properly. Is quite hard to write in English, and if you talk about technical things, when you are not an expert in computing, is even harder! J
Thank you very much!
Gonzalo
Gonzalo
