HELP ME CHOSE A CARD!!
zimu
there's so much stuff out there ad so many sites i'm goig nuts!
basically this is what i want:
-64 MB DDR
-PCI card
-dual monitor (both taking the regular monitor cable; if not i've heard of those other ports but i don't know how i'd connect a regular monitor to that. any ideas?)
-tv out
and thats it!!
i don't want to spend more than say, 80 bucks, but i don't know what to do! help!!
i've looked at the ati radeon 7500 which has dual monitor support but one of the ports is weird and i don't know how i'd make a regular monitor fit into that port.
thanks
Most of the radeons come with a dvi-vga adapter, if it doesn't you can buy one at their website for $20 I believe.
rogo
ok so lets say i buy this:
http://www.pcpart4less.com/product/vcg4m00020.html
it comes for 55 with free shipping;
a) can you find it cheaper?
b) does it definitely have dual monitor support just because its the same thing that someone else posted? thing is there are so many different models and stuff this may just not have dual monitor support which i really want!!
Thanks a lot for your help! much appreciated.
the link you sent didnt' work but i looked it up, it costs 90 bucks?
thanks again.
I see that those links aren't working
Here is a cut and paste from newegg.com
POWERCOLOR ATI RADEON 7500LE 64MB DDR PCI CRT+DVI+TV RETAIL The only PCI Radeon 7500 with 64MB DDR and CRT/TV/DVI multi-display for the UPGRADE SYSTEM
Specifications:
Chipset:ATI 7500 LE Powered by ATI Manufactured by Powercolor
Memory: 64MB DDR
CHARISMA ENGINE supports full Transformation, Clipping and Lighting (T&L) at up to 40.0 million triangles/second peak processing capability
resolutions up to 1600x1200
Ports😀B15 VGA + DVI + RCA Tv-Out
Retail box:Comes with Software and drivers (see pic) Model#: RV2P-B3 Special Free FedEx Saver Shipping
Detail Specs - Product Link - Chipset Info -See It! (image count 4 ) -Price Alert (N82E16814131193) Return to Service
Go to newegg.com
search video cards
and in advanced search use PCI as slot type
and 7500LE as chipset
then search
and you will get the above.
Rogo
