Help me choose video card for P3-800 MHz
kaimeng
18
Hi all,
I own a P3 800 MHz machine, 256 Mb PC133 Ram and ATI Radeon 32 Mb DDR video card.
I want to upgrade my video card to ATI Radeon 9200SE or ATI Radeon 9600SE. How will my video
performance be affected??? The ATI Radeon 9200SE is real cheap now. I may be getting it before I upgrade my whole rig in about 2 years time. Will there be significant improvement in performance if I
upgrade to ATI Radeon 9200SE without upgrading my processor??? I play game at 800x600 resolution
mostly. Thanks a lot!
vshah
19,003
24
a radeon 9100 is actually faster than a 9200. an upgrade to any of the video card yo mentioned will definately max out your processor at 800x600, but the 9100 is still a better card. the 9600 would be overkill.
-Vivan
kaimeng
18
Wow, thanks so much!!! I wonder where I can get my hands on ATI Radeon 9100??? I have only heard
of ATI Radeon 9200SE and non-SE version. By the way, for my rig, is the SE or non-SE version a better
bang for the buck??
jhurst
663
I would go after a Ti4200 instead of a 9200se.....about the same price range
SneakyStuff
4,294
I would also go for a GeForce 4 Ti series card for that comp. Look into the 128 MB Ti 4200 cards.
kaimeng
18
I have benchmark my rig with 3DMark2001SE and it has a score of 2536 for
a normal test, that is, 1024X768 32 bit , Anti-aliasing off, D3D Hardware T&L,
compressed textures. May I know how my computer performed? If I change the video card,
how much difference can I see in my 3DMark2001SE score??? Thanks once again!
Pete
4,953
I hit ~4800 in 3DM01SEv330 at 10x7x32 w/8xAF with a Radeon 9100 (250MHz core and DDR memory) on a P3-700@866, 384MB PC124, Abit BH6. A 9100 should provide a nice boost, but I'd also look into a GF4 or even a very cheap 64MB GF3. I'd recommend 128MB DDR on the video card, but if you insist on pinching pennies, you can get by with 64MB and lowering texture quality in-game. It's probably not worth paying any extra for a 128MB card with a rig as slow as yours, and a used GF3 should go for no more than $30 by now.
Soulkeeper
6,732
155
he could just get that new ati chipset with the integrated radeon 9100 graphics, a cheep P4 , and two sticks of 256mb (the cheapest he can find if he wants, or maybe just one stick of mem). This would turn his purchase into a whole system upgrade for 250 bucks or less
kaimeng
18
Hi,
Thanks for the replies, but I just wanna get a new graphic card. I notice that 9200se memory
interface is 64 bit and 9200 memory is 128 bit. How will this affect their speed on my P3 800 MHz.
What difference will I see in my 3DMark2001SE score for 9200 and 9200se??? Thanks.
Pete
4,953
64-bit memory means essentially half the bandwidth and thus half the framerate in memory-bandwidth-bound settings. At 10x7x32, I'd guess a 9200SE will score about half that of a 9200.
Soulkeeper
6,732
155
yeah go for the wider mem bus
that's pretty much one of the most important things to look at besides which card maker to buy from
kaimeng
18
Hi,
Thanks. I have another problem. I heard there is some problems with certain AGP cards using
a different voltage(3.3 V or 1.5 V). If you placed the video card with the wrong voltage into the AGP
slot, the computer will fry it. Is that true??? I think I'll go for the Radeon 9200 non-SE card but I dont know
whether the voltages match. My Radeon DDR 32 Mb work perfectly for me. Can I assume that Radeon 9200
will work??? That is, it is the same voltage??? Thanks!
Pete
4,953
Your MB is definitely AGP 2x (3.3V), and possibly AGP 4x (1.5V). Just look for a card that's specified for an AGP2x MB. I know a Radeon 9100 works at AGP 2x and 4x, and it'll be a faster card than a 9200.
faye
2,109
wow, finally i find somebody is still using a Pentium 3 generation CPU.
hahaa, i have a P3-700@980, same as ur rig i guess. I am using R9100 128mb, and i am very satisfy about it. if u can find it, get a Ti4200 64mb or 128mb. 4200 is faster but for me my R9100 is still rocking.!!
BFG10K
22,709
3,002
Keep in mind that even with a GPU upgrade your CPU is far too slow to run many of today's games acceptably.
faye
2,109
for me, i know no matter how powerful the videocard is, my cpu is the bottleneck.
I only use this PC for web browsing and wordprocessing.. so i guess it is more than enough... People sometimes just want things to go even smoother but of course for a cheaper price. ...
anyways... get a R9100 will be fine for you or ti4200 , but don't bother getting GeforceFX 5600 5500 series..
Marsumane
1,171
I agree. Maybe even an 8500 if u can find one cheaper then the alternatives. But personally id get the GF4 Ti 4200 128mb card
