Well, what do you want? More bottom, mid, top end? What points are they each tuned at?
the bi turbo will give u better top end, but the technigas will give u close to as much top end, but it has better low and mid range than the bi-turbo.
Sounds like the Technigas has a better power curve. I'd say it is worth it.
Bottom end is priceless.
