- Aug 18, 2002
- 6,115
- 171
- 116
so far i am thinking along the lines of
intel E7500
corsair 750tx power supply
asus P5Q
4GB DDR2 (maybe 1066?)
MSI GTX275
1TB seagate or WD sata
i have been out of the loop for a while... so i'm just getting back into this stuff now.
i just bought a 23" samsung lcd which im happy with so far.. now the system has gotta be upgraded. havent decided on a case yet but i want to build it all up choosing each piece carefully.
it's not going to be a hardcore gaming system but i want it to be as fast as possible for a reasonable price. from my experience, MSI and Asus are both very good...
I'm really not sure for the RAM, I know there are a lot of good ones out there but is it worth it to spend more on lower latency RAM, how much of a difference to expect?
anything in this build that you would do differently?
also... i might consider SSD in the future ... but for now i think a 1TB sata will do more than enough, at the moment im using an old 80GB + 8GB.
i prefer spending a little more to get good quality and a bit faster, as opposed to cheaping out to save a few bucks but sacrifice quality and speed.
intel E7500
asus P5Q
MSI GTX275
