If your teeth work, cavities are filled, root canals are done, caps are in place, cleaning and root planing is done, then there is little more to do. However, you mention missing some teeth.
I'm not missing any teeth, yet. And FWIW, a smile makeover is not purely cosmetic. For me, it is intended to PREVENT me from having to take more drastic action in the future, e.g., dentures or implants.
I've posted the story before, but for brevity I'll summarize it here. When I was 13, my parents forced me to get braces. I hated the idea of them, but they made me get them nonetheless. To rebel, I didn't brush my teeth. By the time I was 15, I has massive decay on most of my front teeth, and the orthodontist insisted that I have the braces removed so that the decay could be addressed. I had 14 fillings on my front teeth done, and 2 root canals. At
15.
Fast forward 20 years. I now have 20 year old dental work that is literally falling apart in my mouth. All of that stuff needs to be repaired, and many of my teeth require crowns to fix the issues. We are talking ~25k worth of dental work, whether or not it is "made pretty." I figure that if I am going to have to spend that much anyway, I would like an aesthetically nice result as well.
Kitchen improvements can have a big effect on the happiness of the home. However, if the improvement is purely cosmetic, do not bother.
Generally agree, but with the sidenote that cosmetic improvements to kitchens and baths improve resale value, and thus are arguably practical expenditures.
Bathroom? Who cares so long as it works. My old home has 50 year old counters, sinks, toilets, floor and wall tile, and a bath with old colors but much improved functionality and quality over modern appliances. To change something of high quality merely for a modern fashion is nuts.
Ah, you have a 50s or 60's era home, where everything was made to last. I have a 90's era home, were most everything was made with a mixture of saw dust and glue. It is functional. But it is also horribly unattractive/
A new water heater can save money in gas or electric bills and is worthwhile.
In our case, we would be adding a hot water tank to our existing off boiler system. That tank will allow us to use our jacuzzi tub, because our existing system is not capable of providing enough hot water for the tub.
Children, now that is the priority. A place for them to play may not be so important if there is a park nearby or if the yard is small. Otherwise, give them the best you can.
Trust me, my son wants for nothing.
An older camping trailer without plumbing can be an improvement over tents when it rains. However, half the fun of camping is sleeping in a tent, feeling the fresh air, and looking up through the mesh top to see the stars and tree limbs swaying in the morning breeze.
I should clarify and say that our "camp" is a trailer with a deck around it, a built in grill, and a brick outdoor fireplace. We do have a tent set up as well, but it is on a platform and more or less a semipermanent structure. A better way to describe our place is the poor man's lake front property.
