Help me choose from these 2 laptops
kuuraketti
Essentially I've got two choices in my price range. I've considered for a laptop to be used for light gaming (WOW, occasional CSS etc.) and surfing the net.
Here are the candidates...(I've only got general info but it's the most important anyways)
1.
CPU: T2250 (Will it be enough or a bottle neck with the graphics card?)
Memory: 2gb
Graphics: GO 7900 GS (512mb)
2.
CPU: Turion TK-57
Memory: 2gb
Graphics: 8400 GS (256mb)
Righto. I'd like to hear some opinion on what games you think these 2 systems could run at the best (not that I dream of playing Crysis lol) to give me an idea. Thanks already.
InflatableBuddha
7,416
#1 without question. Better CPU (C2D) and better graphics (7900 will blow the doors off the 8400GS).
My guess is it will play almost anything you can throw at it, even Crysis (at reduced settings).
Oil
3,552
Actually the CPU in #1 is a Core Duo (1) but that doesn't matter that much since the 7900 GS is MUCH better than the 8400M GS
TheStu
Moderator<br>Mobile Devices & Gadgets
Moderator
Sep 15, 2004
12,089
45
Good catch there OSx86, I was about to say that the first one had what appeared to be a Core Duo identifier. Of course, I have no idea about anything else about the chip... silly new numbering scheme
Rottie
4,795
very light gaming? Go with #2. I would take #1 if I don't have any PC at home and use notebook everyday.
Rockinacoustic
2,460
Even though it's "only" a Core Duo it will still be better than the AMD processor. If you don't care much for battery life or portability then option #1 hands down.
Rockinacoustic
2,460
Originally posted by: VinDSL
Originally posted by: Rottie
Go with #2...
I concur!
#1 is old skool... ;)
SOURCE
Intel T2250 (90.3 nm)
Clock Speed = 1733 MHz
FSB = 533 MHz
L2 cache = 2 MB
TDP = 31 watts
Released: May 2006
Athlon 64 X2 TK-57 (65 nm)
Clock Speed = 1900 MHz
FSB = 800 MHz
L2 cache = 2 x 256 KB
TDP = 31 watts
Released: August 2007
Ahh, but old skool isn't a bad thing Vin ;). The only areas the AMD processor will have on the Intel chip are 64-bit support, and lower power consumption, although I'd imagine the OP wont have any serious considerations to that if he goes with option one anyway.
Even being older technology the Core Duo is still the better performing processor, and it's far from a bottleneck to that graphics card.
