WhipperSnapper
I need to put new tires on my 2002 Saturn SL2. Winter driving performance (snow, ice) is very important but I also need an all year tire since I can't swap between winter tires and summer tires.
Which of these two do you think I should get? Firestone Affinity Touring (came with the car, they were OK) or the Michelin Harmony?
http://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Affinity+Touring
http://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Harmony
I can get the Firestone Affinity tires for $340 installed and the Michelin Harmony for $402 installed.
