- Jun 29, 2009
- 24
- 0
- 0
Ive learned better than to ever buy something without consulting u guys. Ive had an eventful week with my rig to say the least and now I need a new graphics card. I have a budget of 250, but no closed to the idea of buying a card thats a bit cheaper with just a tad less power. I am also open to ur guys suggestions on other cards.
I mostly game at high resolution 24inch 1080p. 550w corsair power supply.
Ive been looking at these 3 cards:
Sapphire Radeon HD 5870
http://www.newegg.com/Product/Produc...82E16814102883
Radeon HD 6870
http://www.newegg.com/Product/Produc...82E16814102909
XFX Radeon HD 6870
http://www.newegg.com/Product/Produc...82E16814150506
I really value ur guys' opinions, so if there is another card you would suggest id consider it. Of the 3 i have, it really comes down to the 5870 and the xfx 6870 but no sure.
thanks guys
Radeon HD 6870
XFX Radeon HD 6870
thanks guys
