Hi all,
This is my first post, kind of long, so here goes:
I'm looking for an LCD monitor to replace my old CRT and save some energy at the same time. Since I'm from Puerto Rico, it's kind of difficult to get a decently priced LCD with DVI. I'm leaning towards a 17", and I found the CMV 726D at a good price. I can get it for around $260-$270 shipped (shipping is a lot no matter where I try to buy it), but that's still cheaper than if I were to buy one with similar specs locally. It's over here:
CMV CT-726D
CT-726D on CMV Website
I haven't been able to find a lot feedback from these LCD's apart from a long thread in another forum and a couple of posts here on Anandtech. Apparently, most people are satisfied with them.
However, I stumbled upon some LCD's by ONE Monitor that caught my attention. I haven't been able to find good info from them, but they look nice for the price I'd be able to get one of them, around $320-$330 shipped. I was able to find that it has a DVI input, even though it says N/A on the website. Here's the link:
ONE-PV178
What I believe the main pros/cons of each LCD are:
CMV CT-726D
pros: Apparently brighter and with higher contrast, 8ms response time (hopefully a complete cycle), DVI cable included, higher viewing angles.
cons: Higher power consumption, 3 year warranty on parts and labor but only 1 year on the panel (I'm guessing back light). Not sure if it has an 8-bit panel or a 6-bit with 2-bit dithering.
ONE-PV178
pros: Lower power consumption, TV Tuner, 3 year warranty on everything. Basically a LCD TV out of the box. Apparently 8-bit panel.
cons: 12ms response time (when compared to the CMV, but by no means bad), no DVI cable (can get one from eBay for around $10 shipped, but it would make the LCD around $350 total).
The PV178 looks better, but I could really care less. I want functionality for a good price.
Basically I haven't decided because I'm not sure if the TV tuner would be really worth it. I would use it, but maybe with the price difference I could buy a better TV Tuner card for my PC and take more advantage of it, right?
So, does anyone have first-hand experience with either of these companies? What do you guys/gals recommend? Would I be far off better buying a tuner card for my PC instead of the one with the LCD?
Thanks in advance!
CMV CT-726D
ONE-PV178
CMV CT-726D
ONE-PV178
Thanks in advance!
