Hi. I'm trying to decide between these two laptops. This isn't a desktop replacement or anything and I won't be playing games on it. It's more or less to be able to have a computer with me when I'm away from home. Also I do photography on the side, so it would be nice to be able to dump photos to the laptop during the shoot so I don't run out of space on my compact flash cards and to also be able to immediately show clients preliminary results.
First the HP dv1000 I have configured as follows:
Pentium M 725 (1.6GHz)
14.0" WXGA BrightView Widescreen (1280x768)
Intel(R) Extreme Graphics designed for Pentium(R)
512MB DDR SDRAM (2x256MB)
40 GB 4200 RPM Hard Drive
FREE Upgrade from DVD to DVD/CD-RW Combo Drive!!
Integrated 56K Modem + 10/100 Ethernet LAN
Second the Compaq v2000 configured with exactly the same specs:
Their prices are identical, but the HP has an extra rebate of $50, so the HP should be $50 cheaper after rebate. I plan on going down to Best Buy or somewhere later to hopefully see them in person, but based on what you know is one of these models better than the other?
Second, here are a couple questions in general. Does the Pentium M 710 (1.4GHz) have the same amount of cache as the 725? Because if so on both models, I can downgrade it to that processor and then upgrade the hard drive to 60GB 5400RPM. If the 710 has as much cache as the 725, then I'd assume the HDD would be the better way to spend the money, is that correct?
Also the Compaq has an additional option for $25 for "Intel(R) Extreme Graphics with productivity ports." What is that? Also they both have additional options for wireless networking (which I need), but should I add that on myself afterwards? Thanks for your time.
