help me choose a fan!
Daemonx
Banned
Jun 21, 2000
595
i want to replace my 2 Sunon 80mm H.O. fans with quieter 80mm fans. it sounds like Newark Airport in my bedroom. any suggestions and where i can obtain them? thanks!
mechBgon
Oct 31, 1999
30,699
Teamawe has 80mm Panaflo L1A (low-rpm) fans that will fix the noise problem for you, and for a decent price too. I bought ten... ; )
toph99
5,505
i have 2 Antec 34.4cfm 80mm fans in my case, they're relativly quiet. check Antec's homepage. i belive they say the decible level, but i'm not positive.
