HELP ME CHOOSE A CASE PLZ!!!
sharkjawz
Hey guys shark here!!! I'm planning on building a new computer in June so i'm looking for parts from now.
My current computer is a XPS-t600...Yeah thats right the old stupid white one so its rrrrealy time to upgrade. So am gonna build one now!!!
I want a really nice computer case with side panel & lights, sexy design,plenty fans. Price doesnt matter. Can anyone please provide me with some options!!!
I like my thermaltake 7000. It comes with a front panel that lights or flashes or nothing.
Comes with a top fan a front fan 2 side fans and a back fan. 2 of the fans are controlled by 2 front nobs. The side is clear and has 2 blue fans. The hard drives are mounted side ways in the bay which I find nice and the slots for your video card etc use plastic retainers instead of screws. I paid $99 at my local shop and then added my own power supply. Its built nice except the front panel is plastic and kinda cheesy but will do.
http://www.pctoys.com/840556018483.html
Thermaltake WinGo V7000 Gaming Tower Case
No Matter What Game you are on................
Thermaltake XaserV WinGo Series for the Gaming Winner !
Features: (to much to list here. be sure and check out the Thermaltake site)
2 Smart Fan fan speed control knobs in front panel & flash EL lamp
Retractable foot stands
Side panel security lock & 3-way front panel lock
Professional cooling system:
Up to 3 90x90x25 mm, 1800rpm, 21dBA
Up to 2 80x80x25 mm, 2050rpm, 21dBA, top & front
WinGo EL lamp with 3 way function inverter
(on/off / flash / lighting)
90mm cooling fan for better ventilation, adjustable fan speed control, 1300rpm~ 3000rpm(exhaust)
Additional side cover with dual 90mm cooling fan:
Up: 90x90x25 mm fan, adjustable fan speed, 1300rpm~3000rpm (intake).
Down: 90x90x25 mm fan,1800rpm, 21dBA. (intake)
Additional Information and Specs from Thermaltake
The Kingwin 523 has a reasonable amount of bling and very good casitude for the money. Some of the CoolerMaster Centurions and the CM Mystique are based on the same chassis. Some of the Aerocools are technically adequate while still having a bit more rice than I like. Most of the Thermaltake cases are technically adequate while ranging from nearly conservative to over-the-top with rice. If you're into cases that look like they're out of a "creature feature" then the Athenatech gaming casses may appeal - also quite inexpensive. If price were no object, I'd probably pair the new Tt Eureka with a nice Seasonic S12 series, Fortron Epsilon series, Silverstone Strider, Enhance or Zippy Emacs PSU, all with active PFC and power output matched to the proposed system - probably not ricey enough for you though...
.bh.
