I am using a NEC FE991SB.. the only complaint I have so far is the two aperture grille lines that runs horizontally across the screen, but that's inherent in all aperture grille CRTs.. so it's not NEC's fault.. plus it's not really that noticable unless you are doing word processing or for whatever reason your display is completely white
