guidinggod
1. What YOUR PC will be used for. That means what types of tasks you'll be performing -- I will be using the PC for trading (multiple data streams and charting software with multiple streaming charts) mostly and general browsing, emails, video/movies/music and some light (browser based) games etc during off market hours.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread -- Ideally $550 in Desktop form (without monitors)
3. What country YOU will be buying YOUR parts from. -- USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU. -- N/A
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc. -- Would prefer Intel based system, no preference on other components like vid card etc.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are. -- I would like to utilise my current HDD (1TB WD Caviar Black) + Asus DVD RW
7. IF YOU plan on overclocking or run the system at default speeds. -- No overclocking or hardcore gaming.
8. What resolution, not monitor size, will you be using? This is key. I would like to use 3 external monitors all running at 1080p @ 60 Hz. I already own these, all have HDMI and DVI inputs.
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it. -- Immediately or as soon as I have some recommendations I'm satisfied with.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? -- I already have a retail version of Win 8.1 Pro x64 on my current PC and if possible would like to migrate that to the new system.
Additional notes: As I understand it, Haswell based motherboards/chipsets/processors can support 3 external displays and would be ideal even without using a discrete GPU card. Ideally that's what I would like, since I want a stable system without messing with drivers, heating, cooling solutions etc (Not very technically savvy as you can tell). Another consideration is physical system size as I would prefer something small(ish) not a big gaming tower type thing.
So far what I've come up with is this build:
Intel DH87MC mobo (has 3 display outputs incl HDMI/DVI/DP) - $125
Intel i5-4430 - $180
Corsair PSU VS350 - $40
Kingston Hyper Blue 2x4GB 1600 Mhz Ram - $80
LIAN LI PC-A05FNB chassis - $95
SAMSUNG 830 Series 2.5-Inch 128GB SATA III MLC - $110
1TB WD Caviar Black + Win 8.1 Pro x64 + Asus DVD-RW (from my current PC) - $0
3 x LG 23EA53V-P Monitors - $0
Total - $630
So a little above my price/budget, not including dp/dvi/hdmi cables I will need.
What should I change to meet my budget? just get rid of the ssd?
Also (since Haswell reviews/descriptions left me a little confused) am I correct in assuming this setup will drive these 3 monitors at 1080p @ 60 Hz in extended mode in Win 8.1 pro thru their dvi/hdmi inputs? Will I need an active DP to HDMI/DVI converter cable or will passive be okay?
Long post, sorry. Thanks in advance.
Total - $630
