WarDemon666
So far im getting an 800 watt inverter and its going to power a normal powersupply in the car. What im trying to design is a way to shut down the computer automatically when i remove the key. I found some software that will hibernate the computer when 2 pins of the LTP port are touched, with a countdown.... so heres what im thinking....
3 relays...
when the ignition is ON a relay turns on the inverter, and hits the power on the computer, when i remove the key, a relay touches the two ltp pins and the countdown begins, upon shutdown there is no more power and of the hard drive etc cables, so another relay switches off the inverter. when a key is put back the inverter is then turned on and the computer also...
Will this be possible? I drew out the diagram on paper but i have an old scanner and it only works in win98, so i cant scan it.
Can anyone make me a schematic or just tell me if this will work, and if so, what kind of adjustments must I make to my plan..
Thanks!
3 relays...
Thanks!
