Okay guys, I need some serious help building my new computer. Here is what I have so far:
Processor: AMD 64 3400+
Mobo: Asus K8V SE or MSI K8N Neo Plat or ABIT KV8
Graphics Card: BFG 6800GT
Ram: I have no idea. Looking at Corsair right now. Opinions? Want 1 or 2GB
Hard Drives: Need two 80GB's or two 100GB's.
Case and PSU: I don't know. Want something quiet that will offer great cooling options without adding anything
Okay, so that was my basic plan from the start. Problem is, I'm having second thoughts on my processor. Is the 3400 worth the price difference over the 3200? I don't mind paying for the performance difference, I just want to make sure it's somewhat worth it. I also thought about going up to the 3500 939 pin or even the 3700, but it doesn't seem logical to spend more money on that with PCI-E right around the corner. What do you think?
As for my mobo, if I do go with the 3400 or 3200, what do you think is the best out of the above three? I've heard good things about the MSI, and another person told me that there were some problems with the Asus, but I haven't heard anything about that.
Hard Drives: Well, I don't know. I don't know how RAID works very well, but it doesn't function with S-ATA drives, right? So what's better?
Ram: Looking at Corsair with PC3200. Want either 1GB or 2GB right now. 1GB should be fine but I need to be able to go to 2GB later on if I need to. A friend of mine swears by Crucial, but I'm liking the Corsairs right now.. I just have no idea what model to look at.
Case and PSU: Another subject on which I am clueless. I need at least 400W, but I'd like more than that. What case would you recommend? Also, what are my options if I wanted a water cooled case?
Okay, I think that's everything. Wow, I thought I was more decided than that, but I guess I'm not. So as you can see, I'm in need of a lot of help.
Thanks!
Thanks!
