Hi,
I need a stand alone RS-232C logger, so I don't have to have it connected to a PC to log data with my electrical multimeter.
The meter can support a query every one second and I need a device that can be programmed to inquire the meter via RS-232C command "QM" with a variable interval adjustable from 1 sec to 1 hour, then log the result in .csv format that can be downloaded by connecting the PC to the same serial port. It also needs to have a reasonably accurate time-base for making an accurate inquiry interval.
Thanks
Thanks
