- Aug 22, 2001
- 178
- 0
- 0
One of my hardrives recently crashed and the computer is pretty old so I'm planning on starting from scratch.
My budget: ~$2000
I use the computer mostly for web design - Lots of Photoshop and Flash. I'm planning on using it for 3d as well in the future. I play absolutely 0 games lol.
What I have already:
Monitor, Keyboard/Mouse, and speakers.
What I need:
(Also these are choice I made from the readings I've done in the forum, if you can recommend something else that would be great)
Processor:
AMD Dual Core Opteron 275 Italy 2.2Ghz $748.00 or
AMD Dual Core Opteron 270 Italy 2.0Ghz $495.00
I've been told that I should go with the Opterons. However, I was wondering if I would really see a difference between the 2.2 Ghz and 2.0 Ghz. I've been using Intel all my lifetime and I want to change to AMD. I'm wondering if the ~$250 is really worth is for .2 more Ghz.
Motherboard:
I've I heard I should get a Tyan board. Which model I'm not really sure it would be really helpful if somone can recommend me one. I'm guessing the motherboard will be around $400.
Case:
http://www.newegg.com/Product/Product.asp?Item=N82E16811112089 $220.00
Wanted a case sort of like the Powermac G5's, this is the closest I could find lol.
Graphics card:
http://www.newegg.com/Product/Product.asp?Item=N82E16814133142 $499.00
I'm using the computer as a workstation so I'm thinking I dont need a gaming card. This is the card I use at school and it runs pretty well so I'm thinking I shuold just purchase this as well. But $500 is pricey for a video card so I'm wondering if I would be fine with something like the 7800GT.
Memory:
I'm not too sure whats a good brand.
Hardrive:
Western Digital Raptor WD740GD 74GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Operating System:
I'm not sure if I should go with the Windows XP Pro or Windows XP 64.
Also has anyone expierenced with Monarch Computers? I see they can build the "barebones" system (http://www.monarchcomputer.com/Merchant...Code=80233&Category_Code=AMDBarebones)
so I'm guessing all I would have to do is add the video card and hardrive.
I'm sort of new to building computers so I'm trying to get it prebuilt and I heard Alienwares are rip offs. Also if you think I'm missing or forgetting something please let me know. Sorry for so many questions and thanks a ton!
My budget: ~$2000
What I need:
Processor:
Motherboard:
Case:
Graphics card:
Memory:
Hardrive:
Operating System:
