all from
newegg
Cases PC - ATX - Mini/Med Tower
ENLIGHT MEDIUM ATX TOWER CASE MODEL # EN-72370X3C4 - OEM with 300Watts Power Supply - Pentium 4 Ready & AMD Approved. 4 5.25" Bays, 2 3.5" Bays & 1 3.5"(Hidden). One Internal Case Fan Totally backward compatible with earlier Intel and AMD CPUs Interchangeable motherboard stakes for dynamic motherboard installation options. Snap-On drive brackets for hassle-free Floppy &/ Hard drive installation. EMI & Thermal-Ready supporting high-speed Intel Pentium 4 & AMD CPUs. Strategic fan placements for efficient cooling. Perfect for case modifications. Rolled edges for reduce installation injuries. (Dimensions: 195 x 425 x 480 mm / 7.7" W x 16.7" H x18.9" D ) N82E16811116119 $44.00 $44.00
CD ROM
Lite On 52x Cd Rom - Model LTN-526 -RETAILE-IDE Interface, support all PIO, DMA, Ultra DMA modes. Innovated SMART-X® to get the fastest CD-DAE/VCD data extraction speed by request. RETAIL Package with manu, driver, cable and screws. N82E16827101201 $27.00 $27.00
Floppy Drives
MITSUMI D359M3 FDD 1.44MB 3.5INCH - OEM N82E16821103104 $9.00 $9.00
Hard Drives - IDE
WD WESTERN DIGITAL EIDE HARD DRIVE 20GB 7200RPM MODEL # WD200BB - OEM, DRIVE ONLY Caviar 3.5 inch Form Ultra ATA 100 8.9ms Seek Time 2mb Cache Buffer - 3 Year Manufacturer Warranty - 20.0 gb 7200 rpm N82E16822137116 $65.00 $65.00
Keyboards - English
Microsoft OEM Internet Keyboard and IntelliMouse PS/2 Bundle INTERNET KEYBOARD: Equipped with (10) hot keys that support Internet and e-mail functions, so users can launch their browser and surf the Web directly from their keyboards. Or, they can open their e-mail program and check messages with the push of a button. Also, a sleep key and two user-programmable hot keys, labeled "calculator" and "My Computer". Does not have a removable Palmrest. MOUSE: 2-button mouse with Wheel (that can be used as third button). With the included IntelliPoint Software, users can "scroll" and "zoom" natively withing Microsoft Office 97 applications as well as a host of other compatible programs. N82E16823109106 $24.00 $24.00
Memory - PC (DDR)
OCZ DDR RAM 256MB PC-2400 300Hz OCZ300256. CAS 2 Performance DDR Overclockable memory. OEM, Lifetime Warranty. N82E16820146800 $70.00 $70.00
Modems
Diamond SupraMax 56K V.92 PCI Modem Data/fax. Fax speeds up to 14,400 bit/s. Features Quick Connect, Modem-on-hold: the end user can put the modem on hold and stay connedted to the Internet (User must have call waiting service to use this feature). PCM upstream - increases maximum upload speed to 44 Kbps. N82E16825116102 $17.00 $17.00
Motherboards - AMD
Asus A7N266-C NVIDIA nFORCE 415-D Chipset 266/200MHz FSB Motherboard with Dolby Digital Audio- OEM
Supports AMD Socket A Athlon XP/Athlon/Duron Processors
AGP 4X/AGP Pro Advanced Graphics Slot for 3D Graphics
Integrated APU(Audio Processor Unit) in MCP-D built-in Dolby Digital (AC-3) Encoder. FOR BUNDLES ONLY! N82E16813131002 $105.00 $105.00
Processors - AMD Duron
AMD Duron 1.0 GHZ Socket A, 200FSBPGA Processor Retail Box Version N82E16819104149 $58.00 $58.00
Video Cards
VISIONTEK Xtasy 5632 GEFORCE2 GTS-V 4X/2X 32MB DDR AGP - OEM
This VGA card offers high performance based on the GeForce2 GTS-V chipset and 32mb 256 bit DDR memory. Visiontek is the only Nvidia board partner to offer this card. Part# 72440.0 N82E16814129007 $46.00 $46.00
subtotal - $465
shipping will be around $50
this should be a decent enough system for what u wanna do
