- Nov 8, 2010
- 5,747
- 342
- 126
Beginning of last year I tilled up a portion of my yard that used to be a garden (back before I bought the house) and tried a veggie garden in it. Cherry tomato plants did well, cucumbers and peppers did not. Plus, I had a LOT of weeds that were relentless. I tried keeping up but it was a lost cause.
I'm hoping to get a better handle on it this year, and was thinking of going with a raised bed garden with some fresh soil to both help keep weeds away and prevent the soil from holding water like it did with heavy rains last year.
Here is what I'm starting with:
It measures roughly 13' x 9'. My plan is to cover what is there now with a weed barrier, throw a bunch of soil on top and top that off with compost. Should I till what's there before adding the rest?
As for the sides, what's the best wood to use? I'll probably have to cut the 13' long section down to 2x 7 1/2' sections, since my truck bed is only 6 1/2' long. I've been reading that pressure treated isn't good for vegetable gardens, since the chemicals can seep into the soil and into the plants. So I've been looking at dimensional lumber at Lowes/Home Depot, something like 2" x 10" wood, does the type of wood matter? I'm looking to get maybe 5yrs out of it, until I most likely move. Also, is there a benefit to using something like a retaining wall block for joints over brackets and screws?
I'll get the soil delivered via dump truck and wheelbarrow it to the garden, if my calculations are correct 13' x 9' x 8" deep is roughly 3 cubic yards?
Anything I'm overlooking? Any other advice you can throw my way? Once I get the physical garden figured out, I'll need to look into automatic drip irrigation since I'll be away from home for weeks at a time this summer and want to make sure everything still gets proper hydration.
