Help me build a pc
Roberdots
8
alright guys wrestling is over but besides being an athlete im a nerd at heart but..... beyond the processor and ram i have no idea what im taking about when it comes to pcs
now i mostly play on consoles but THE WITCHER 2 !!!!!!!!
SKYRIM AND MASS EFFECT 3 WITH MODS !!!!!!!!!!!!!!!!!!!
and guild wars 2 looks cool
help me understand what i need for a custom built computer to play these games on max settings
what parts do i buy ?
BladeVenom
13,365
16
This is usually best asked in General Hardware.
Here's the things you should list:
PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
3. What country YOU will be buying YOUR parts from.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds.
8. What resolution YOU plan on gaming with.
9. WHEN do you plan to build it?
10. Don't ask for a build configuration critique or rating if you are thin skinned.
The above information IS NEEDED, in order that WE can help YOU make wise judgments on YOUR purchases :laugh:
