help me build a gaming rig !
Gadzookie
Antec Solution SLK3000-B Black Steel ATX Mid Tower Computer Case 49.00
FSP Group (Fortron Source) AX450-PN 450W Power Supply 49.99
AMD Athlon 64 3200+ Venice 1GHz FSB Socket 939 Processor 190.00
EPoX EP-9NPA+Ultra Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard 95.00
CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) System Memory 107.00
Maxtor DiamondMax 10 6B250S0 250GB 7200 RPM 16MB Cache SATA Hard Drive 103.00
SONY Black 1.44MB 3.5" Internal Floppy Drive 9.99
NEC Black IDE DVD Burner Model ND-3540A 37.99
POWERCOLOR R43CA-GD3D Radeon X800GT 256MB 256-bit GDDR3 PCI-E Video Card 159.00
what do you guys think ? i went with the x800gt cuase i heard it was btter then the 6600gt
Total 907.97
drop 3200 and get a 3000 instead from ewiz.com.. and buy a DFI nf4 board w/ that saved money and OC the living sh!t out of it..
Total 907.97
Youd be better off getting good ram now. like mine or other TCCQ samsung ram.
should i spend a little more and get a 6800 nu ?
Check the fs/t forums and see if you can score a 6800GT from someone who's going to a 7800. The 6800GT is basically the same card as the 6800U, just clocked lower, but it normally can be overclocked to at least 6800U speed itself! I would say that is the best option.
I don't know about the X800GT. Haven't heard good things. Apparently the X800XL is the one to go for right now.
