VisionSeeker
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming and work.
2. What YOUR budget is.
About 3k.
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
The only thing im a fanboy of is performance. Ive tried AMD and intel, Nvidia and ATi. I guess, i heart WD though. Their drives have never failed on me. This rig has Intel, ATI, and WD.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Maybe the DvD burner, but i dont think the new mobo has IDE. I have some data on my old IDE HDs id like to get, but its not crucial. Ill figure something out.
6. IF YOU have searched and/or read similar threads.
I have read about 3 or 4 threads but they all had budgets of around 5-650,
not really applicable.
7. IF YOU plan on overclocking or run the system at default speeds.
Yes, using aircooling. The G.Skill Ram im planning on getting is rated DDR3 1333 at 1.5v, i figure it should probably run at 1600 with 1.65v(or less, hopefully) without too much hassle right?
If i could get the CPU to 3.6 id be satisfied, to 3.8 elated, and at 4.0ghz id be worried about the proc's health and longevity, so not that high.
Later on in the upgrade cycle i plan on trying watercooling, but not now.
8. What resolution YOU plan on gaming with.
1920x1080 or '1080p'
9. WHEN do you plan to build it?
Very soon, this week.
10. Don't ask for a build configuration critique or rating if you are thin skinned.
Nothing wrong with constructive criticism.
The plan for this build is to have a clear upgrade path. The LGA 1366 package should be around awhile still. Dual 5970’s later. Id heard that theres an EVGA board that lets you mix and match ATI and Nvidia cards for Xfire and PhysX on the same board, but I don’t know the specifics of that. Or whether having 3 PCI-E cards in the box is worth it all, considering the limited bandwidth available for multiple cards.
Open SSD bays for raid 0. Large starting data drive capacity. 12GB of Ram to start, with room for 12 more. Large, roomy, full tower case.
The only part im not sure fits this philosophy is the 850 watt PSU. Sure its enough for the current build, but how bout when I build it out with 2 5970’s, 2-3 2TB WD drives, and 2-4 SSDs, and perhaps another DVD/blu-ray drive.
Well, here are the specifics, lemme know what you think.
COOLER MASTER HAF X RC-942-KKN1 ATX Full Tower Computer Case
http://www.newegg.com/Product/Produc...82E16811119225
I might also get some extra fans for this case cuz i dont think it comes with all the fans.
CORSAIR Professional Series AX850 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Modular PSU
http://www.newegg.com/Product/Produc...82E16817139015
ASUS Rampage III Extreme LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813131642
Intel Core i7-960 Bloomfield 3.2GHz LGA 1366 130W Quad-Core Desktop Processor BX80601960
http://www.newegg.com/Product/Produc...82E16819115224
I find this to be the best LGA 1366 proc currently, thats not sayin much, they're all horrendously overpriced.
COOLER MASTER Intel Core i7 compatible V10 Hybrid TEC RR-B2P-UV10-GP 120mm CPU Cooler
http://www.newegg.com/Product/Produc...82E16835103056
G.SKILL Ripjaws Series 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9T-12GBRL
http://www.newegg.com/Product/Produc...82E16820231356
Newegg is listing them as 1.5v default sticks, i hope they have a lil headroom.
XFX HD-597A-CNB9 Radeon HD 5970 Black Edition 2GB 512 (256 x 2)-bit GDDR5 PCI Express 2.1 x16
http://www.newegg.com/Product/Produc...82E16814150460
Western Digital Caviar Black WD2001FASS 2TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Produc...82E16822136456
Pioneer Black Blu-ray Disc/DVD/CD Writer SATA BDR-205BKS - OEM
http://www.newegg.com/Product/Produc...82E16827129051
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Produc...82E16832116758
Should i go with the Home premium and save the 30 bucks? What do i get for the extra cost?
Logitech K350 Black USB 2.4 GHz Wireless Ergonomic Keyboard
http://www.newegg.com/Product/Produc...82E16823126076
Logitech Performance Black Tilt Wheel 2.4 GHz Wireless Laser Mouse MX
http://www.newegg.com/Product/Produc...82E16826104321
Gaming and work.
About 3k.
US
