- Jul 12, 2000
- 12,444
- 2
- 81
Well, the time has come at last. My dual Athlon rig has served me faithfully and flawlessly for 2+ years, and is starting to show its age. (1500+'s on an AMD 760) Clearly the choice for performance right now is the P4c/865 from what I have read, the only two problems being 1) I have not built an Intel rig since my p3 700e@1200 with the exception of this Quad PPro that I'm posting from
D) and 2) I am on a budget.
I am merely asking for recomendations as far as:
- Which P4 is the best value overclocker; the 2.4c?
- What type of memory would be needed to hit around 3 GHz with stability?
- What cooling would be appropriate and not overkill?
- Which motherboards are most highly regarded at the moment?
Also, I'm a little confused about if I get an 800MHz FSB processor at 2.4GHz will I still be able to reach around 3.0 GHz through cranking up the FSB without maxing out my memory? TIA,
Nate
Nate
