- Nov 8, 2010
- 354
- 3
- 81
1. What YOUR PC will be used for.
1080P Gaming @ 120hz
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$2,000
3. What country YOU will be buying YOUR parts from.
USA
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I will be keeping my keyboard, mouse, speakers, monitor, PSU, and Hard drives
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking is fine.
8. What resolution, not monitor size, will you be using?
1080P
9. WHEN do you plan to build it?
Now
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
No
My rig has seen a lot and is ready for retirement. It's been a helluva good CPU and it's hard for me not to be an intel fanboy but the latest games are causing my rig to come up short. I'd really like a system that performs well on Unreal Engine 4 games, specifically Ark: Survival Evolved.
$2,000
USA
1080P
Now
No
