:( Help Me before I through this friggin system against the WALL!!!!!!!!!!!
jcovercash
9,064
OK I put my new dual rig togahter. Well I hit the power button and fans , lights came on. But no beeps. Also there was no video output. I know the video card is good. And its not the chips, i tried my dads single duron and still no boot. What can i do.??????
What is wrong???
Josh
Shooters
3,100
You're using registered RAM right with that Tyan Thunder right? What kind of power supply are you using? It sounds like it could be a bad mobo.
xxsk8er101xx
298
check for a jumper on the board to switc from single cpu to dual cpu AND make sure you set the correct multplier setting and front side bus.
Had a similar problem and then i set the multiplier to the right setting and it booted up. Also on your board, maybe there is some kind of jumper that sets it to 2 cpu mode or something.
Also try reseating the cards and ram. Even the cpu's. Sometimes if it isn't in right it won't post and no beeps.
HappyFace
6,265
If you have another board, test the CPUs and ram. If you have a defective part, you can use the process of elimination to pinpoint the source of the problem.
BFG10K
22,709
3,003
Take out all of your components except for the bare essentials and try booting the system.
stonecold3169
2,060
about 15 minutes ago I just put my 1.4ghz athlon into my KT7A RAID board, and until I manually set the speed, it would boot up only every 4 times exactly, or when I'd clear the cmos... it's worth a shot
jcovercash
9,064
Ok sorry it took a while for me to reply, I havent had alot of acces to a computer. I tried the 1700s in my dads computer they worked fine, so there clear.
Then i tried the ram, yes it is regiested ddr ecc, no boot it did the same thing on his that mine did. Fans run no beeps, blank screen. So i figure it ahs to be the ram, hopfully its not the mb and the ram, ill have to wait till i get soem more ram to see if its the board
Thanks
Josh
wasnlos
448
Hi,
i looked at your system specs and if it's not a typo you're trying to run normal XP-CPUs on the dual-board instead of MP-CPUs ?
Could that be the reason?
:confused:
jcovercash
9,064
I have been told by alot of people that the xps work fine in the dual board
Josh
and as i said above, I belive its the ram becuase my dads system doesnt work with it
Josh
