Help me AT-obiwan! 4890 or 2x 5770's?
Single 4890 or 2x5770's?
  • 4890
  • 2x 5770's
  • Other suggestion that doesn't involve anything Nvidia.
RussianSensation
19,458
765
I thought you already own a 4890?
5770s will leave a single 4890 in the dust! You said you can sell your 4890 for $195. Dual 5770's can be had for $300. $105 to get 5870 performance from your 4890 is a good upgrade if you don't mind trying out CF (i.e. they will match 5870 with ease up to 1920x1200 if not more).
SunnyD
Belgian Waffler
Jan 2, 2001
32,675
www.neftastic.com
Which is why I'm asking... :)
jtisgeek
295
I say 5850 easy to deal with don't have to worry about crossfire , See gains in all games lower power and heat.
Shmee
8,275
3,159
The AT-AT says get a 5850 or two. And Darth Vader says to get an SSD.
jthunderloc
606
2 5770s will be slightly slower then 2 4890s, but will use less power, generate less heat and have DX11. Either setup should be on par or slightly above a 5870. If you can get 2 of the 5770s at the price you linked earlier that's a helluva setup for $250 and you could easily get $150 for your current 4890. that's 5870 performance for $100 after its all said and done! That gets my vote.
-Wes
dark0anima
33
This. isn't the performance between xfire 5770 and 5850 around the same? The 5850 is just a bit more and it is a single gpu solution, in the long run you can add another 5850 for cheap when you feel it isn't fast enough.
happy medium
14,387
480
2 5770's will beat a 5870 in most games. And 5770's will also overclock well. 950/1300+ stock volts.
2 5750's are about the same as a 5850.
