help me and my co-worker settle a disagreement (a deceptively challenging question inside)
glenn1
25,383
1,013
Thanks for checking out this thread and helping us out. The question is actually quite simple, yet devilishly hard as well.
Question: In standard modern usage, does written English generally contain more consonants, or vowels? That is to say, if you chose a book off a shelf or the NY Times 100 bestsellers list at random, which would tally the greater total of letters inside, vowels or consonants?
I've not been able to find the find the answer to this question on the web anywhere, and we both are absolutely convinced that our (opposite) convictions are correct, but neither one of us can really give a reasonably confident reason for our opinion. So i'm going to try this two different ways, if i can get an official answer that's great, otherwise we'll bow to the collective opinion of the ATOT crew via the magic of the ATOT poll.
OS
15,581
It wouldn't be hard for someone who knows perl to write some code that does a tally I think. I could probably do it in C.
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,268
Take your post here, and add them both up. Chances are that it is representative, so there you go.
Rallispec
12,375
10
60 consonants
39 vowels
i'll go with consonants for 400, alex.
Apr 5, 2000
13,256
Consonants. Count the number of vowels and consonants in your own post for reference. There aren't enough vowels to equal the number of consonants used
SWirth86
1,939
Question In standard modern usage does written English generally contain more consonants or vowels That is to say if you chose a book off a shelf or the NY Times bestsellers list at random which would tally the greater total of letters inside vowels or consonants
Ok, I picked these two sentances as a random estimate of English Literature.
218 Charcters
138 Consonants (Just counted them...it was boring)
80 Vowels
So, more consonats than vowels, and I can prove it*:)
*Of course, it will vary from sentence to sentance, but these two should be a fairly accurate estimate of the ratio.
Rallispec
12,375
10
218 Charcters
80 Vowels
i got 60% of letteres used being consonents in my earlier post using another sentence., looks you're findings show 58%, pretty damn close. i think we are right.
SWirth86
1,939
218 Charcters
80 Vowels
Of course I am right; I am never wrong.
Sep 6, 2002
73
There have to be more consonants because they're needed to create distinct sounds. You can do "th", "cr", "sh", "fl", etc. but you cant put many vowels together for that purpose. You rarely see "oa" as in boa, "io" as in biometric, or "eo" as in creole. Its not exactly scientific, but consonants are needed to create different words. Or something like that..
FoBoT
63,084
15
fobot.com
um, i have no idea what this means
Markov Models: Exercise 2
Q = {v, c}
P(X1=v) = 0.3
P(X1=c) = 1 - 0.3 = 0.7
P(Xi=v|Xi-1=v) = 0.01
P(Xi=c|Xi-1=v) = 1 - 0.01 = 0.99
P(Xi=v|Xi-1=c) = P(Xi=v,Xi-1=c) / P(Xi-1=c) =
[P(Xi=v) - P(Xi-1=v) P(Xi=v|Xi-1=v)] / P(Xi-1=c) =
[0.3 - 0.003] / 0.7 = 0.42
P(Xi=c|Xi-1=c) = 1 - 0.42 = 0.58
The Markov property means (here) that the probability of occurrence for vowels and consonants only depend on the immediately preceding letter. This is clearly a false assumption for most languages. For example, the probability of observing a consonant after n preceding consonants is usually higher than the probability of observing a consonant after n+1 preceding consonants.
link
AzNmAnJLH
1,785
It's obvious consonants are used more often in all languages that uses the roman alphabet
rstlne....<<<<<<wheel o fortune
djheater
14,637
WHAT BOOK WAS WRITTEN WITHOUT USING THE LETTER "E"?
"La Disparition" is a French novel of complex intrique by George Perec, written without using the letter "E". It was published in France in 1969 and translated into English, as in 1995.
Get "The Void", by Gilbert Adair a French novel translated to English... in both cases WITHOUT using the letter e... anywhere.... it's odd, to say the least.
Haircut
2,248
Consonants definitely.
According to this site, vowels occur as 380 out of every 1000 letters.
Obviously consonants must then appear as 620 out of every 1000 letters, thus thus ratio of consonants to vowels is approx 5:3.
yakko
25,455
Gadsby by Ernest Vincent Wright was also written without the letter E. Linky.
Ameesh
23,686
Q = {v, c}
P(X1=v) = 0.3
link
this doesnt fit our question exactly and isnt really a proper markovian chain. the Markovian assumption is that future states are not reliant on the past states but in language that isn't true.
but by tweaking that assumption to hold that 1 past state is releavent it provides some interesting results.
wyvrn
10,074
This is one of the more interesting threads I have seen on ATOT lately. My educated guess is consonants, for reasons already stated above.
bizmark
Banned
Feb 4, 2002
2,311
damn that's some crazy stuff.
notfred
38,241
4
#!/usr/bin/perl
$bookfile = "bookfile.txt";
open BOOK, "<$bookfile" || die "can't open file";
while ( <BOOK> ){
$book .= $_;
close BOOK;
@letters = split //, $book;
foreach $letter(@letters){
if ($letter =~ m/[aeiouy]/i){$vowel++}
elsif($letter =~ m/[bcdfghjklmnpqrstvwxz]/i){$cons++}
print "$vowel vowels and $cons consonants in $bookfile\n";
that will test a book saved as plain text.
edit actually works now.
On this page there are 4142 vowels and 6207 consonants in bookfile.txt
Moonbeam
74,905
6,788
That's about 40 to 60 % in favor of consonants, notfred, notfar, hehe, from the average I posted.
Robet
144
How did this argument start? You guys must have the most boring workplace ever.
As for the guy that wrote the book without using the letter E, one side of his brain must have been over developed. Now was it the left side because he analyzed all of the possible words in order to find a fit without an E. Otherwise, it could have been the right side because he was creative enough to come up with a novel without Es. Could he have been one of those whole brained people? Hmmm.
Anyway, these are the stats for my post:
276 consonants
185 vowels
