Help me air-cool this Pressie system better
Rookie
My signature has my system profile and it is VERY thorough.
When I play WoW everything maxed out running fullscreen in widescreen mode, My processor tops out at 70c and my ambient case temp doesn't top 33c.
How can I air-cool this a little better? Any ideas?
The fans are intake-bottom front, exhaust-top rear.
Can anyone recommend a good SATA HD Cooler? My intake is right in front of the HD and i THINK this might help...
If your cpu is at 70C with your case at 33C I would look to shielding the cpu with a forced vent to the rear (with fan). It sounds like there may be some recirculation going on in your case, with the cool air being vented out without sufficently cooling your cpu. If you can measure exhaust temps that would be ideal. You may find that your top fan is venting out all your cool air rather than cooling your cpu.
