Help! Math problem of the week
Tung
2,977
My sister has this problem she can't solve. I can't solve it either! Please help out :eek:
You have a 100 ML flash containing 60 ML of 20% acid. You need to make a 40% solution. On the shelf there are three bottles:
A 200 ML bottle full of a 50% solution
A 200 ML bottle half full of a 60% solution
A 200 ML bottle with 10 ML of a 70% solution
Describe how you would make a 40% solution without using another container.
Thanks in advance.
kt
6,032
1,348
pour 50ML of 50% into the 10ML of 70% bottle, then add 40ML of 20% and you 100ML of 40% acid in the bottle that originally contained 10ML of 70% acid.
minendo
35,560
22
<< Describe how you would make a 40% solution without using another container. >>
I think this means you wont be able to make accurate measurments.
dullard
26,201
4,871
There are an infinite amount of ways to do this:
You have 12 mL acid and 48 mL water at the moment.
Lets add stuff from flask into the third bottle. The third bottle has 7 mL acid and 3 mL water.
Now you have 19 mL acid and 51 mL water.
Is this the concentration you want?
19/(19+51) = 27.1%.
No.
Lets forget bottle two for now (for fun you can use it).
Add 2*x mL of the stuff from bottle one to your new 200 mL bottle.
Thus you will be adding x mL acid and x mL water.
Now you have (x+19) mL acid and (x+51) mL water.
You want a specific concentration:
(x+19)/(x+19+x+51) = 4/10
or
(x+19)/(2x+70)=4/10
Solve for x:
x+19 = 4/10 * (2x+70)
x+19 = 4/5*x + 28
1/5*x = 9
x = 9*5 = 45.
Check the concentration:
You now have 19+45 = 64 mL acid and 51+45 = 96 mL water.
64/(64+96) = 40%.
Did you overflow the bottle?
64 mL acid + 96 mL water = 160 mL.
No - your problem is solved.
Edit: to accurately measure the 2 x = 90 mL, use your now empty 100 mL flask.
