jazzisjazz
mornin to ya'll
I get the blue screen message machine check exception which includes the following
0x0000009c (0x00000000,0x8054DA70,oxCC0000FF,0x20040189)
I googled it. It seems the cpu is seeing some sort of error that cannot be corrected for - may be coming from hardware ( vague guess from the pages I skimmed through) . I wiggled my vid card and modem card with no effect,reduced cpu to normal speed ( 2.4@3.06) with no effect, then switched out memory sticks with no effect. It sees to happen soon after power on, you may get into windows and open a program and you may not get into windows before bluescreen. Any ideas?
By the way
WinXP SP2
Abit IT7 Max
kingston hyperx
mushkinpc3200 2-2-2
maxtor 40gb in raid 1
visiontek geforce3 Ti200
56k modem
dvd-rom
2 cd-burners
thanks for any help,
jazzisjazz
UPDATE
First more details
I have disconnected power to all cd/dvd drives
and disconnected all printers/scanners/speakers/usb cables etc.
The IT7 was setup to boot from 1 of 2 total raid arrays
a 40gb disk i was using to save files on was/is connected to the main(non raid) ata controller of the board.
With the raid array drives connected to power
If I disconnect the 40gb files disk the raid controller sees it's disks(lists them at bios level) and the boot continues untill I get the message that I need to insert a boot disk to continue - If operating properly it should see a boot disk in a raid array.
If I connect the 40gb files disk it will try to boot into windows( with previous failures it now continues to the page with the options for safe mode, last good and normal) - and whatever choice is made almost immeadiately gives the blue screen last file listed in safe mode boot (before bluescreen) is iomdisk.sys ------- This is a guess - It may be trying to boot from the 40gb files drive because it cannot find a bootable disk in the raid setup - although it should.
With the raid array drives disconnected from power
and 40gb files drive powered - it will continue to the boot options page and whatever you choose bluescreen will immeadiately follow
and the 40gb files drive also disconnected - it continues untill it messages that it needs a boot drive to continue.
Possible conclusions
anytime the 40gb file disk is connected I get blue screen - can I assume that either the controller, the driver for the controller or the disk itself is bad(seems to work ok in a usb2 enclosure connected to another machine - would it be a good test to reconnect a cdrom alone on this controller to see if I get a blue screen?
The bootable raid array is fubared somehow - the best i can hope for is to pull some data from the drive and start over
Hope I have made things clearer rather than more confusing.
What do you guys think?
By the way
WinXP SP2
Abit IT7 Max
kingston hyperx
mushkinpc3200 2-2-2
56k modem
dvd-rom
2 cd-burners
jazzisjazz
UPDATE
First more details
