Help! low fps on d3 !
Wizard12
53
I ran d3 benchmark few times on my comp and I'm getting extremly low fps for my system.
36-42 fps on 1280x1028 with everything on except AA .
and the weird thing is, even when I change aa it doesent decrease the fps.
also, the game seems to be accesing the hd a lot when results in major slowdows.
any suggestions what might be the problem?
Lonyo
21,938
Does the system perform as expected in other games/benchmarks, (ie: Doom 3 specific issue) or is it a system wide issue?
Appledrop
2,340
What 3dmark 2005 score do you get then? Btw i think you mean 3200+ in your sig, not that it matters much. Sounds like drivers if you are sure that everything else is in order - try different nv drivers, try removing audigy perhaps, and im assuming your NF4 chipset drivers are all installed
edit: it could also perhaps be vsync, which would explain why farcry is fine, while d3 (an openGL game) is not.. Check vsync is turned off.
ty1er
807
Have you tried running the timedemo twice in a row?
The reason i ask is because when ever i run the timedemo the first Run always runs pretty bad, it accesses the HD way to much. But then when i run it a second time directly after the first run, the timedemo runs nice and smooth.
Here are my results
First run = ~40fps
2nd run, 3rd run, 4th...etc. = ~80fps (and no HD access during the run)
Wizard12
53
"Btw i think you mean 3200+ in your sig, not that it matters much."
doh :)
anywayz, yeah vsync helped...perfomance jumped to 58 fps (but still the same when using no aa - AA X8 which is very weird)
second, I noticed that the first time I load benchmarks/levels it keeps accesing the hard drives...
but the second time I do it it does not and runs more smoothly...
what is this problem?
Wizard12
53
"The reason i ask is because when ever i run the timedemo the first Run always runs pretty bad, it accesses the HD way to much. But then when i run it a second time directly after the first run, the timedemo runs nice and smooth. "
yeah , exactly...same here...
but when I play the game its the same...all those hd accessing...so It's not really playable...
BFG10K
22,709
3,007
Did you remember to install your chipset drivers? Also try closing down background programs and system tray icons.
lavaheadache
6,893
14
doom 3 needs to build up cache to run smoothly, thats why when running the time demo a second time through it is much smoother, this is not a problem just the way the game is designed. As far as it happening while your playing that should happen only for the first few minutes of play. The game usually pauses briefly the first time it loads a certain effect/ texture. I learned to get in the habit of scrolling through my weapons and reloading then maybe even taking a shot just to load that stuff into the cache before I start playing(doing this really helps). Another thing to do is go through the doom config file(I believe its in the base folder) and set it up for your system youd be surprised how bad it auto detects your system. Since your system is so close to mine YOu should copy and paste my settings into the folder, making a backup of your original in case it doesnt work. I have done this before and it has helped people like you out before.
unbindall
bind "ENTER" "_button2"
bind "ESCAPE" "togglemenu"
bind "SPACE" "_moveup"
bind "/" "_impulse14"
bind "0" "_impulse10"
bind "1" "_impulse0"
bind "2" "_impulse1"
bind "3" "_impulse2"
bind "4" "_impulse3"
bind "5" "_impulse4"
bind "6" "_impulse5"
bind "7" "_impulse6"
bind "8" "_impulse7"
bind "9" "_impulse8"
bind "[" "_impulse15"
bind "\" "_mlook"
bind "]" "_impulse14"
bind "a" "_moveleft"
bind "c" "_movedown"
bind "d" "_moveright"
bind "f" "_impulse11"
bind "q" "_impulse9"
bind "r" "_impulse13"
bind "s" "_back"
bind "t" "clientMessageMode"
bind "w" "_forward"
bind "y" "clientMessageMode 1"
bind "z" "_zoom"
bind "BACKSPACE" "clientDropWeapon"
bind "PAUSE" "pause"
bind "UPARROW" "_forward"
bind "DOWNARROW" "_back"
bind "LEFTARROW" "_left"
bind "RIGHTARROW" "_right"
bind "ALT" "_strafe"
bind "CTRL" "_attack"
bind "SHIFT" "_moveDown"
bind "DEL" "_lookdown"
bind "PGDN" "_lookup"
bind "END" "_impulse18"
bind "F1" "_impulse28"
bind "F2" "_impulse29"
bind "F3" "_impulse17"
bind "F5" "savegame quick"
bind "F6" "_impulse20"
bind "F7" "_impulse22"
bind "F9" "loadgame quick"
bind "F12" "screenshot"
bind "MOUSE1" "_attack"
bind "MOUSE2" "_speed"
bind "MOUSE3" "_zoom"
bind "MWHEELDOWN" "_impulse14"
bind "MWHEELUP" "_impulse15"
seta radiant_entityMode "0"
seta gui_mediumFontLimit "0.60"
seta gui_smallFontLimit "0.30"
seta net_socksPassword ""
seta net_socksUsername ""
seta net_socksPort "1080"
seta net_socksServer ""
seta net_socksEnabled "0"
seta win_ypos "22"
seta win_xpos "3"
seta sys_lang "english"
seta s_numberOfSpeakers "2"
seta s_doorDistanceAdd "150"
seta s_globalFraction "0.8"
seta s_subFraction "0.75"
seta s_playDefaultSound "1"
seta s_volume_dB "0"
seta s_meterTopTime "2000"
seta s_reverse "0"
seta s_spatializationDecay "2"
seta s_maxSoundsPerShader "0"
seta r_debugArrowStep "120"
seta r_debugLineWidth "1"
seta r_debugLineDepthTest "0"
seta r_cgFragmentProfile "best"
seta r_cgVertexProfile "best"
seta r_forceLoadImages "0"
seta r_shadows "1"
seta r_skipBump "0"
seta r_skipSpecular "0"
seta r_skipNewAmbient "0"
seta r_renderer "best"
seta r_brightness "1"
seta r_gamma "1"
seta r_swapInterval "0"
seta r_useIndexBuffers "0"
seta r_customHeight "486"
seta r_customWidth "720"
seta r_fullscreen "1"
seta r_mode "7"
seta r_multiSamples "4"
seta image_downSizeLimit "256"
seta image_ignoreHighQuality "0"
seta image_downSizeBumpLimit "256"
seta image_downSizeSpecularLimit "64"
seta image_downSizeBump "0"
seta image_downSizeSpecular "0"
seta image_useCache "1"
seta image_cacheMegs "384"
seta image_cacheMinK "2048"
seta image_usePrecompressedTextures "0"
seta image_useNormalCompression "0"
seta image_useAllFormats "1"
seta image_useCompression "0"
seta image_preload "1"
seta image_roundDown "1"
seta image_forceDownSize "0"
seta image_downSize "0"
seta image_lodbias "0"
seta image_anisotropy "16"
seta image_filter "GL_LINEAR_MIPMAP_NEAREST"
seta gui_filter_game "0"
seta gui_filter_idle "0"
seta gui_filter_gameType "0"
seta gui_filter_players "0"
seta gui_filter_password "0"
seta net_master4 ""
seta net_master3 ""
seta net_master2 ""
seta net_master1 ""
seta net_clientMaxRate "16000"
seta net_serverMaxClientRate "16000"
seta m_strafeSmooth "4"
seta m_smooth "1"
seta m_strafeScale "6.25"
seta m_yaw "0.022"
seta m_pitch "0.022"
seta sensitivity "13.428572"
seta in_toggleZoom "0"
seta in_toggleCrouch "0"
seta in_toggleRun "0"
seta in_alwaysRun "0"
seta in_freeLook "1"
seta in_anglespeedkey "1.5"
seta in_pitchspeed "140"
seta in_yawspeed "140"
seta gui_configServerRate "0"
seta com_guid "KwMGBVsK7qw"
seta com_product_lang_ext "1"
seta com_videoRam "256"
seta com_showFPS "1"
seta com_purgeAll "0"
seta com_machineSpec "3"
seta g_decals "1"
seta g_projectileLights "1"
seta g_doubleVision "1"
seta g_muzzleFlash "1"
seta mod_validSkins "skins/characters/player/marine_mp;skins/characters/player/marine_mp_green;skins/characters/player/marine_mp_blue;skins/characters/player/marine_mp_red;skins/characters/player/marine_mp_yellow"
seta g_mapCycle "mapcycle"
seta g_voteFlags "0"
seta g_gameReviewPause "10"
seta g_countDown "10"
seta g_password ""
seta g_showBrass "1"
seta g_showProjectilePct "0"
seta g_showHud "1"
seta g_showPlayerShadow "0"
seta g_showcamerainfo "0"
seta g_healthTakeLimit "25"
seta g_healthTakeAmt "5"
seta g_healthTakeTime "5"
seta g_useDynamicProtection "1"
seta g_armorProtectionMP "0.6"
seta g_armorProtection "0.3"
seta g_damageScale "1"
seta g_nightmare "0"
seta g_bloodEffects "1"
seta r_aspectRatio "0"
seta ui_showGun "1"
seta ui_autoReload "1"
seta ui_autoSwitch "1"
seta ui_team "Red"
seta ui_skin "skins/characters/player/marine_mp"
seta ui_name "player"
seta si_spectators "1"
seta si_usePass "0"
seta si_warmup "0"
seta si_teamDamage "0"
seta si_timeLimit "10"
seta si_fragLimit "10"
seta si_maxPlayers "4"
seta si_map "game/mp/d3dm1"
seta si_gameType "singleplayer"
seta si_name "DOOM Server"
seta g_spectatorChat "0"
use this, best of luck
Wizard12
53
I didn't get any imporvement... :(
yet now I always run the demo in the begining and that way it does not acces the hd so much while I'm playing...
Bumrush99
3,334
194
You have to run the demo twice to get an accurate score.. FYI, I get 90fps in 1280 HQ on my rig, which is very similiar to yours. Also, make sure you do not force refresh rates in the NV Control Panel. Disable that and run the tests twice
BFG10K
22,709
3,007
To precache the demos add a '1' to the end of your command. In this case I don't think it's the problem as the performance is poor during actual gameplay, which it shouldn't be.
I didn't see an answer to my question: do you have the latest chipset drivers installed for your system?
Wizard12
53
"I didn't see an answer to my question: do you have the latest chipset drivers installed for your system"
I guess so, my system was installed 2 weeks ago...
TantrumusMaximus
515
I actually reburned my system once because of that stuttering! If you haven't taken this advice please try running as he suggested:
"timedemo demo1 1"
You won't need to run timedemos twice anymore because the system will precache the demo and not access the HD while the demo is running. I was under the impression I had a system problem.
Also make sure you are running the latest chipset drivers which I think is 6.53 now. I had the best luck with the 71.89 display drivers.
