Help: Leaking faucet
Qacer
2,721
Good morning everybody. I'm not a handyman, but once in a while, I try to do some "easy" DIY projects. So, I have a leaking faucet problem. The water is leaking from the base.
This is my faucet (partially dismantled):
Here is a picture of it from the bottom of the sink:
I've decided to break for a bit. I didn't want to continue dismantling the faucet if I can fix the leaking problem without doing so.
Anyway, as you can see from the pictures, the water leaks from the base on the top and also at the bottom of the sink. Is there an easy fix to this? Can I just caulk the bottom part of the faucet (below the sink) to stop water from dripping?
Thanks!
PottedMeat
12,363
475
Thanks!
heh
http://www.moen.com/consumer-support/faq said:
Not Found
The requested URL /consumer-support/faq was not found on this server.
There's probably a torn gasket in there, you should be able to find a compatible replacement at home depot or lowes. I wouldn't caulk the thing unless it's really really temporary.
Qacer
2,721
heh
Yeah, I tried going to Moen's website earlier, but it's down. I was planning on going to HD anyway. I just wanted to make sure that I have my list of stuff to get.
PottedMeat
12,363
475
I'd just bring the middle part with me to HD.
Lanyap
8,243
2,330
Probably an O-ring gasket. You should be able to find a repair kit at Lowes or home depot that has the O-ring and other internal parts that probably need replacing also.
Qacer
2,721
Middle part? Is that the cartridge?
I found a really good video on Youtube that I've been using to come up with my parts list:
http://www.youtube.com/watch?v=F5M4feAc7Y8
and
http://www.youtube.com/watch?v=xMbr7wqwgTY
I got the faucet spout out, and the bottom most O-ring seems good, but I will replace it anyway. It seems like a lot of Moen faucets leak from the base and to fix it involves replacing the cartridge. Are all Moen cartridges created equally? I can't pull up the Moen website, so I can't really tell the model number of my faucet.
jaha2000
949
Just take it out and bring it with you to HD.
Its a plumbing job, at least 3 trips will be required anyways
Rastus
4,704
There's probably a repair kit at HD that will have gaskets and nylon parts in it to repair Moen faucets. Shouldn't cost more than 5-6 bucks.
Qacer
2,721
Take what out, though? If you are talking about the cartridge, I tried pulling it out already. It's hard. It seems like I need a special tool to loosen it first.
olds
50,101
771
The spigot the water comes out of should slide straight up. There should be an o ring under there.
stargazr
4,101
3,586
That's a good video, note removing the clip. It is a cartridge valve on that type of faucet that uses one knob for hot & cold. I just replaced one this morning, was around $20. I have a Moen removal tool from the last one I replaced - it was really tight.
Qacer
2,721
Dammit. Tried replacing the cartridge and the damn plastic adapters keep breaking. I'm on my second adapter now. I had to drive back to HD to get the first one replace. Tsk. Tsk.
One hard son of a gun to replace:
It broke already a second one:
How the heck do I pull this cartridge out?
I've got no drinking water for the time being. Hah.
Qacer
2,721
No sinks in your bathroom?
Yeah, tap water. My faucet was filtered. That's what I meant.
Anyway, I was able to finally pull out the cartridge. Half of the second removal adapter broke, but I still managed to loosen up the cartridge and pull it out.
Five hours and $50+ worth of parts and tools later... it's all done. I guess 5 hours to fix a leaking faucet is not too bad for a DIY noob. My next project will be refurbishing some old, hardwood floors. Let's see how bad I'll screw that one up. Hah!
PottedMeat
12,363
475
Damn that was a lot of trouble. If that happened to me, the next time I had a similar leaky faucet I'd just get the cheapest one like it for ~$80.
0roo0roo
64,795
84
Yea no kidding, you shoulda gotten a new faucet, cost only a few bucks more and all new parts, and pretty easy to put in.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
I haven't been in the market for a decent faucet in a long time, but I'd think a faucet that wasn't going to require repairs about every other year would cost somewhere in the ballpark of double what he spent.
More importantly though, he learned a valuable skill. The next time he has to do something like that, it'll take him a fraction of the time.
olds
50,101
771
More importantly though, he learned a valuable skill. The next time he has to do something like that, it'll take him a fraction of the time he'll call a plumber.
FTFY
