HELP! laptop keyboard keeps making system sounds
alby4ever
For some reason starting today, whenever I press the E or A keys after or before each other (ex: typing "great") it makes a system beep sound. It's driving me nuts! =\....... I notice that when I type "ea" really fast there's a pause then there's the sound and then the a appears. If I press a and e together it also produces the sound. Anybody who knows how to fix this please help =\ Any help is appreciated.
BTW I have a Toshiba M10-S405 (centrino) if that helps. Thanks =\
If it is a system beep then try it outside of windows. Boot to a DOS CD or something like that and try typing for awhile. If you had stuck keys I would imagine that you would have beeping from pretty much the moment you power on the unit.
