HELP: KK266-R Front Panel Installation
Dhanu
How do I figure out which way the connectors go onto the mobo? There's nothing about this in the manual. They tell you which pins are for each LED etc. How do I figure out which side of the connector is the ground or anode etc... so that I can align it with the right pins? Please help
Thanks,
Dhanu...
foofoo
1,344
hi,
it doesnt matter for the power switch or the reset switch.
for the others, just try one direction and if it doesnt light, reverse it. i know this sounds a bit dodgey, but you wont hurt anything if the ide or power leds are backward, the led just wont light.
GremlinHater
342
Just got the same board and ran into the same problem, the manual has a "sketchy" diagram of the connections, you just need to count of the pinheads, I finally figured it however I will tell you that I believe all the connections face the sameway EXCEPT the HDD connection which is reversed as I found out, if you have any more problems, PM me.
Edit: I believe the majority of the connections, the text side faces outward as I figured that be the common sense way to do it. Anyways, good luck.
hairygit
135
I just got this sucker up and running.
Moved like a fast cheetah with the wind behind him.
Unfortunately - after 30 minutes of windows, everything ceased. No LED, no fan no nothing.
If you have any ideas, please email me or pm me.
hj1234@go.com
Cheers, and good luck,
It was good while it lasted.
