Help....IWill XP333...jumper settings
CzarChasm
4
Im building my first sys from scratch with:
Iwill xp333 v2.1
256 OCZ PC2700 DDR
Aopen Gforce2TI 64
Maxtor 60GB 133/7200
What out of the box jumper settings should i use for max stable performance? Specifically the core voltage (2.5v, 2.6v, or 2.7v)
I would GREATLY appreciate any input
Thanx
-cc-
Frosty3799
3,795
hey i just got mine set up about a week ago (in my sig for specs)
umm those votlage adjustments on the motherboard are for the ram. i would suggest putting them both on pins 2-3 so you get 2.8v going to the ram.. thats the setting i use, and system is nice and stable, its been up for 3 days straight now, no problems, no slowdowns, and passes prime95 like a champ.
for the CPU voltage, the adjustments are in bios on the same page as all the multiplier settings, fsb settings, etc. i have my voltage at 1.8 right now, and my temps w/ a thermoengine are about 40 idle and 45 full load.
what CPU are you using, and is it unlocked?
PM me if you have any other questions.
Josh
EDIT: PM is private message, and to enable your private messages, click on profile, and you will find the option in there.
rbV5
12,632
<< i would suggest putting them both on pins 2-3 so you get 2.8v going to the ram >>
Thats where I'm at as well (undocumented), also I have my Core v set to Auto in bios and my Tbird is purring along nicely 24/7 at the settings in my sig. 41/47 idle/load.
