- Jul 12, 2002
- 15
- 0
- 0
Here are my specs
AMD Athlon XP 1800 1.53ghz
Abit NV7-133R motherboard
GeForce 4 TI4200 64mb
512mb PC2100 Crucial ram
Win XP
I have the latest drivers installed and Windows Update has been run.
My problem is my computer keeps crashing while I am playing games.
Recently the problem has gotten so severe that I cannot play any games for more than a few minutes without it crashing.
It is not unique to one game it happens when I am playing Far Cry, WC3, UT2004 etc
What happens is the computer freezes and the screen becomes a jumbled mess of colors. The only way to fix this is to pull the power plug out and re-insert it. Then when you start the computer it will boot normally. If you don't pull the plug out it boots with the screen all crazy.
Is this because of overheating??
I went into the BIOS settings and checked the temp of the CPU. I noticed it was too hot, the warning temperature was 75 degrees and the CPU was at like 78.
I have removed one side of the computers case but I think the CPU may be too hot or perhaps it is damaged from already being burnt.
I removed the cpu fan and cleaned a BUNCH of dust out that was on top of the heatsink. I think the dust was preventing the fan from cooling the heatink and processor.
I just now installed MBProbe it is supposed to measure the temp of the processor. And it is showing the CPU temp as 144.5F farenheit!!!
Is this accurate and why would it be doing this.
How can I fix my computer??
Please any help is appreciated.
Win XP
