Help! Is my Motherboard done?
335Xray
9
Originally posted by: mechBgon
Troubleshooting starter
  1. Overview of the problem
    (brief "Cliff Notes" description of the problem)
    Computer intitially didn't even boot up. I would push power buttom, CPU and PS fans would spin for a sec and then stop. Power light on front of case would flash green on and off. Unplug power supply, plug it back in it would do the same thing.
    Reset the bios with jumpers, rechecked all PS connections, looked for bulging caps. Nothing. Reset Bios a couple of more times, messed with a bunch of wires, computer powers up!
    But...no video output at all. The DVD drives try and access themselves back and forth top one, bottom one, back and forth, no real HD activity and that is where I am at.
    I first thought the PS was bad, now I think it is the MB.
    Thoughts?
    Rig worked fine the day before.
  2. Windows XP SP2
    • Norton
    • Kerio
  3. My hardware
    • System brand & model, if it?s a pre-built system such as a Dell, HP, Gateway, etc. If it?s not, fill in as much of the information below as you can.
    • MSI K8N Neo2 Platinum Bios ver 1.4
      AMD Athlon64 3200+ Winchester
      Mem: 2.80V, HT Freq: 4x, AGP: 1.65v
      Max Memclock 200Mhz
      1GB Mushkin 3200 Black LII V2 DDR (2.5-3-3-8) 1T
      PNY 6800NU 12x1, 6vp Core clock: 386 Mem Clock: 824
      Maxtor 300 GB SATA 7200rpm, 16mb cache
      Maxtor 200GB IDE 7200rpm, 8mb cache
      Dell 2001FP (1600x1200)
      XP Pro SP2
      Antec Sonata with True 380W PS
      +5V 35A, +12V 24A, +3.3V 28A
  4. Other information that might be relevant
    (any other information that might be related to the problem)
ch33zw1z
39,797
20,392
Unplug everything except what you need to boot, CPU/VGA/RAM and of course power :) (only plug in what you need). If still the same issue, pull out the RAM and try to boot. The mobo should sound off POST errors. If it doesn't then it's probably the mobo. Try the same with the video and post back with results or questions.
335Xray
9
OK, unplugged my 2 other HDs, both optical drives, the floppy drive, my extra USB hub.
Nothing.
Pulled out one memory stick at a time, swapped their locations and the sticks.
Nothing.
Pulled both sticks, no post error.
Pulled the videocard...
Nothing.
Even tried hooking up other HDs, nothing.
Anymore ideas?
ch33zw1z
39,797
20,392
Last Resort is to reseat the CPU, otherwise your down to bad PSU or mobo...more than likely mobo
