I've have just finished upgrading my computer. After using for a few weeks it has started to smell like something is burning. I just bought a new powersupply, cpu, motherboard, and an AMD heatsink & fan that came with the cpu. I pull out my heatsink and toook a look. All I notice is that the heatsink glue at the bottom has a small square missing from where the cpu touches the heatsink. Is that right, I've never had that happen before, but I used to put on my own thermal paste. I look at the cpu and system temp. and sys. temp is 22 degrees and the cpu temp won't climb any higher than 42. Should I put some thermal paste on?
Thanks
Thanks
