Today when I started up my computer I got this message:
"A problem has been detected and windows has been shut down to prevent damage to your computer.
A process of thread crucial to system operation has unexpectedly exited or been terminated.
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow thses steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advance Startup Options, and then select Safe Mode.
Technical Information:
*** STOP: 0x000000F4 (0x00000003, 0x86a19da0, 0x86a19f14, 0x805c749a)
Beginning dump of physical memory
Physical memory dump complete.
Contact your system administrator or technical support group for further assistance. "
So seeing this for the first time, I restarted my computer, for some reason windows wouldn't boot unless I had a boot floppy or CD. So I put the Win XP cd in, windows then booted, then crashed and returned to the above screen.
..What does this all mean???
