Help!! IRQL_NOT_LESS_OR_EQUAL Help!!
JazminSienna
Stupid me!! I really did it to my computer this time, and layed awake most of the night stressing it.
I attempted to restore WinXP back two days-I had some mouse issues and thought this would help. It restored, but my extra hard drive appeared to be missing. So I undid the restore, and now Windows will not load, and the message begins A problem....
IRQL_NOT_LESS_OR_EQUAL-then it tells me to remove hardware or software that is causing the problem-what did I do and how to I fix it?
Thanks in advance!
I had that error. Mine was caused by a front side bus being set to high. Not sure if that is your problem or not. Good luck
I have the same problem too and also trace the problem due to the inability of my SCSCI card to run anything above the 33.3 mhz PCI bus.
What's the hex numbers in parentheses on the blue screen? Post 'em here and I'll try to look 'em up.
You can also get 'em from an event in the system event log with source "save dump."
Try resetting your cmos. And don't overclock
