Help---Iogear USB 2.0 ALi Chip set card problems
sak
Hey i was one of the ppl who was lucky to get the CompUSA Iogear USB 2.0 card. Modle GIC220U-b which has the daam ALi chipset.
Hey i dont know if its just my computer or if others are getting this problem to..i have winXP sp1a.
when i initially installed my card with the ALi chipset it seemed to be working fine..
i had on usb hub connected to it..which had a scanner among other items connected to it.. at first it seem to work fine..but now i cant even see the hub on the 2.0 card.
when i unplug USB hub and connect it back it says that its found a new divice as normal..but then comes back saying that USB divice is not installed properly..
i tried to reinstall the driver but that does not seem to help..
has anyone able to figure out how to get this daam ALi chipset usb 2.0 card working.
TIA
