joanne firus
I had it installed in my laptop.
A few hours ago I closed the lid on my laptop, but I noticed that it wasn't going into sleep mode (which it usually does, since I've set it up as such).
I opened the lid again, and found out that even though the laptop was running nothing was coming up on the screen.
I can't quite remember what I did after that, but I must've either held down the power button to force it to shut down and popped out the battery, or I went straight ahead and popped out the battery (after disconnecting the power supply).
Either way, I put the battery back on, and turned on the laptop.
And it kept telling me that it couldn't detect any harddrives!
I have since taken the SSD out of the laptop, and connected to my iMac using the USB-to-SATA adapter from my Seagate USB harddrive.
I've noticed that, without the SSD connected to the adapter, the lights on the adapter light up as normal; but once I connect the SSD to it, the light goes off.
Needless to say, the iMac isn't detecting the SSD either (even though it has absolutely NO trouble detecting any drives formatted to SATA/NTFS, as I've installed the Paragon NTFS drivers on it).
Did I just turn my SSD into a useless doorstop?
