Help Installing WinXP... Possible Hard Drive problem
Summary about says it all... I have a 200 GB hdd I'd like to install XP on. I've been using this 200 GB drive for the past few months simply for storage. It's broken into a 40GB and 146 GB partitions, both NTFS.
I go to install XP on the 40 GB partition. First series of copying files goes fine. When the computer reboots, I get the "Error loading operating system" message. When using FIXMBR or FDISK /MBR, I get a message saying that the MBR is corrupt and if I try to fix it, I may destroy data or partions, etc, etc.
If I fix MBR, and try installing from scratch again, cycle repeats...I've drive destroying both partitions, repartitioning, and attempting install... still no go.
Any thoughts? Thanks.
Have you run Memtest to check RAM?
Is the first partition a primary partition set active? You can't boot from a logical drive in an extended partition.
