HELP installing vf700 on 6600GT AGP
InlineFour
Banned
Nov 1, 2005
3,194
one of the two holes the zalman heatink uses is for the bottom chipset heatink. so should i just stick on the included purple heatsinks instead?
fbrdphreak
17,555
Including the make & model of your 6600GT might help. Pics can't hurt either.
You do realize you need to removal all of the existing cooling right....
InlineFour
Banned
Nov 1, 2005
3,194
nevermind, i was using the wrong hole. it's a PNY 6600gt agp. anyway, i realized you can't use the included ramsinks.
