Help installing programs in XP pro
I am running windows XP professional edition. Computer is 1.4 Ghz Athlon, All in wonder radeon 8500, SB Audigy, 640 RAM, Asus DVD ROM E612. I hope this is enough info for the problem, but we'll see...
Anyways, I have several things Ive tried to install (Half Life, the sims, Palm software, just to name a few). I'll insert the cd, the autorun program will run, and I will choose the option to install the program (some have different options). The autorun window will close, and then nothing. If I open task manager, it will have setup.exe and wowexec.exe running, but with no memory usage. I tried installing Half Life on a friends comp, also running XP pro, and it started the installation fine. Whats going on? I cant anyone else with this problem. Can someone help me please? As you can see, its a variety of programs, so I dont know whats going on. I have installed all the windows updates, and this problem happens even if I manually open the setup/install file (and not just let autoplay run). I have been able install Office 2000 and some other programs without any problem. Any ideas? Thanks in advance.
