I use the heatsink that came with the CPU (q6600). I took the heatsink off the cpu because I noticed it wasn't 100% securely mounted, and now I have problem trying to put it in. I remember all I need to do is push the notches into the hole diagonally, 2 at a time, but I just can't. Then I try really hard and i found that the plastic side pins that are on both side of the black pin that is suppose to go to the hole is bent, but I was able to get the black pin in. Am I suppose to push the notches to bend the 2 outer plastic pin so the black pin in the middle can go into the hole on the motherboard?
