Help! Installing chipset drivers errors
Frew
2,550
I want to install the Nvidia chipset drivers for Nforce3. Here is the log.
nforce-installer log file '/var/log/nvidia-nforce-installer.log'
creation time: Sat Dec 11 16:21:54 2004
option status:
license pre-accepted : false
expert : false
uninstall : false
driver info : false
no precompiled interface : false
no ncurses color : false
no questions : false
silent : false
Installer install prefix : /usr
kernel source path : (not specified)
net kernel install path : (not specified)
audio kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
Using: nvidia-installer ncurses user interface
-> Found package NVIDIA network driver for Linux-x86
-> Found package NVIDIA audio driver for Linux-x86
-> Please select packages for installation:
Selections:
NVIDIA network driver for Linux-x86 (1.0-10)
NVIDIA audio driver for Linux-x86 (1.0-1)
-> Starting install of NVIDIA network driver for Linux-x86
-> Checking for loaded module nvnet
-> Checking for loaded module forcedeth
-> License accepted.
-> Skipping check for conflicting rpms.
-> /proc/version is Linux version 2.6.9-1.667
(bhcompile@tweety.build.redhat.com) (gcc version 3.4.2 20041017 (Red Hat
3.4.2-6.fc3)) #1 Tue Nov 2 14:41:25 EST 2004
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
-> Kernel source path: '/lib/modules/2.6.9-1.667/source'
-> Kernel output path: '/lib/modules/2.6.9-1.667/build'
-> Performing cc_version_check with CC="cc".
-> gcc-version-check failed:
./nvnet/conftest.sh: line 9: cc: command not found
Could not compile gcc-version-check.c
If you know what you are doing and want to ignore the gcc version check, sel
ect "No" to continue installation. Otherwise, select "Yes" to abort install
ation, set the CC environment variable to the name of the compiler used to c
ompile your kernel, and restart installation. Abort now? (Answer: Yes)
