Help installing apache on FC5
Kristi2k
I'm having a hard time installing Apache on FC5. This is what I get for an error:
[root@Osiris apache_1.3.34]# ./configure --prefix=/usr/local/etc/httpd/
Configuring for Apache, Version 1.3.34
+ using installation path layout: Apache (config.layout)
Creating Makefile
Creating Configuration.apaci in src
Creating Makefile in src
+ configured for Linux platform
Error: could not find any of these C compilers
anywhere in your PATH: gcc cc acc c89
Configure terminated
Is there a good reason you're doing this by hand and not using "yum install httpd" or something to that effect?
For that matter why the heck are you using a 1.3 build? The 2.0 series is well established now and quite secure.
Some of us still don't like 2.x:
  1. The new threading model doesn't inspire confidence.
  2. There is a reason security oriented projects like OpenBSD aren't going with it (besides just the license).
  3. It is less free than the 1.3 branch (earlier branch anyhow, I think the later releases are tainted with the new license).
To OP: Use yum.
Originally posted by: Kristi2k
Does PHP4 play well with the new branch?
It'd be a pretty ridiculous problem if the webserver and php from the yum repositories didn't work. At any rate, there's a far higher chance of success than trying to install it all yourself. If they don't work, file a bug report and/or move on to a distro that doesn't concentrate on the bleeing edge.
To OP: Use yum.
Most webhosts I'm on is still on 1.3.x but I had trouble using it on my windows xp dev machine. Apache2 works fine though
